v7.19+dev0731 - July 31 2024
* Includes feature branch: FX automation overhaul
* Includes branch: internal buffering/antfx modernizations
* Includes branch: internal cleanups
* Includes feature branch: 128 track groups
* Includes feature branch: more combinations of peak display modes
* Includes feature branch: RGB profile tweak
+ API: improve undo-dirty tagging of various item/take APIs
+ ARA: do not seek to loop start when setting loop points from ARA plugins
+ Automation: increase UI processing rates
+ Control surfaces: increase input reading rate [t=231630]
+ Lanes: when track has only one lane and it is not already playing, do not automatically set that lane playing after edits [t=293259]
+ Metronome/click: fix mouse behavior in click pattern editor with retina monitors and high time signatures
+ Render: show project regions in render peaks display
+ Tempo envelope: fix possible bad click pattern created when pencil-drawing tempo envelope points
+ Video: automatically refresh video processors that use input_get_name() when a track/take name changes [t=293212]
+ Video: fix loading presets via ReaScript when UI is hidden [t=293212]
# Render: improve behavior when creating time selection and mouse moves outside the window
# Tempo/time signature: fix inserting tempo change immediately before a time signature change [p=2799205]
