卧室制作人博客:Dr Phase Is A FREE Phaser Pedal Plugin Audiority
Audiority releases Dr Phase, a freeware guitar pedal VST plugin modeled after the vintage MXR Phase 90.
A phase shifter, more commonly known as a ‘phaser,’ is a modulation effect that generates filter peaks and modulates their center frequencies by sweeping them up and down the sound spectrum.
This leads to a sound that is similar to a chorus or a flanger.
The original MXR Phase 90 pedal by Jim Dunlop was known for its simplicity, where one could choose between a subtle and shimmery effect to a high-velocity swooshing sound.
Audiority’s Dr. Phase is visually similar to the MXR pedal. But the functions have been digitized for our convenience.
Changing the ‘speed’ dial on the plugin changes the frequency of the phaser. Setting it to a lower speed will give the sound a subtle shimmer, and a higher rate will yield a more wavy sound.
Just like a stompbox, you can turn the pedal on or off using the switch below the speed dial. This can be helpful during automation when you don’t necessarily want to run the pedal throughout your track.
The ‘Toolbar’ allows you to manage plugin presets and set global parameters.
The ‘HQ’ button enables oversampling. This can help reduce aliasing when your signal is saturating.
There is a ‘vintage mode’ that gives you sounds reminiscent of the 70s and 80s when guitar players extensively used a phaser in their music. This removes the feedback resistor from the circuit for a smoother phasing effect.
The global controls include ‘in,’ ‘out,’ and ‘mix.’
If you are a guitar player, then this plugin is definitely for you. While the MXR pedal has a kind of warmth that can be hard to emulate digitally, the plugin saves you the hassle of recording an amp and the excess noise that comes with it. You can record a clean channel and adjust your sound to give it the phase shifter effect.
A phaser, however, is not just limited to guitar and bass players to give their sound an edge.
Adding a phaser to drums can give it an additional gritty texture that can sound great if you make electronic dance music.
When a phaser is added to synth leads and even brass, it can yield exciting results too.
The plugin is available in 64-bit for both Windows and macOS users.
It is VST2, VST3, and AU compatible and requires 2GB of free space.
You can download it for free from the Audiority website by signing up with your email address.
Dr Phase (64-bit VST2/VST/AU plugin formats for Windows & macOS)
资讯出处:Dr Phase Is A FREE Phaser Pedal Plugin Audiority - Bedroom Producers Blog
