v6.41 - November 11 2021
+ ARA: preserve ARA plugin state when moving tracks or items to subproject [t=259138]
+ Configuration export: allow export to continue when some files fail (e.g. due to very long path names) [t=258954]
+ Envelopes: consistently describe take envelopes as “take envelopes” and not “item envelopes” in actions, menus, and dialogs
+ JSFX: fix line clipping bug [t=217249]
+ Locking: improve behavior of toggle lock mode actions (auto-enable locking when enabling lock mode)
+ Master meter: fix 1-pixel RMS/LUFS drawing error when using 0dB red threshold [p=2491792]
+ Menus: when razor edits exist, don’t gray out menu actions that will operate on razor edit areas (cut, copy, delete, duplicate, etc)
+ Metronome: fix click speed multiplier when many tempo changes exist [t=259441]
+ MIDI hardware: add per-output device setting to disable MIDI reset messages
+ MIDI hardware: fix persistence of preference to reset MIDI pitch/CC on playback stop
+ Mouse modifiers: fix some actions to set default mouse modifiers
+ MusicXML: fix importing xml files with certain comments [t=259026]
+ Notation editor: fix beaming pattern in 8/4 and 8/8 [t=259376]
+ Opus: fix multichannel regression in opusfile update in 6.39
+ ReaScript: allow using MIDIEditor_GetSetting_str() to query event details from the MIDI list editor
+ ReaScript: increase size of task control prompt [t=259053]
+ ReaVerb: slight performance improvement in LL mode with smaller max-FFT sizes
+ Theme: default theme image fixes resulting from volume label change
+ Theme: restore 6.38 HiDPI image margin scaling logic
