REAPER v7.22+dev0909
v7.22+dev0909 - September 9 2024
* Includes feature branch: batch converter updates
* Includes feature branch: time signature marker editing improvements
* Includes feature branch: additional render normalization options
* Includes feature branch: render display improvements
* Includes feature branch: FX automation overhaul
* Includes branch: internal cleanups
* Includes feature branch: 128 track groups
* Includes feature branch: more combinations of peak display modes
+ API: add PCM_SOURCE_EXT_SET_PREVIEW_LOOPCNT available for track preview registers
+ Convert: when padding with silence, apply fades before padding
+ Lanes: MIDI export ignores lanes that are not playing back
+ MIDI: add preference to avoid setting MIDI items on non-playing lanes visible
+ Metering: fix non-master stereo RMS post-fader meter readout inaccuracy
+ Metronome/click source: always show editable text version of click pattern
+ ReaScript: clarify that GetSelectedMediaItem(), CountSelectedMediaItems() are discouraged (and why) rather than deprecated
+ Ruler: add actions, ruler context menu entries to set or reset project start time or start measure
+ SD2: adjust media item length after reloading media with new parameters
+ SD2: leave source properties dialog open after reloading media
+ SD2: support saving current decoding parameters as default
+ Transport: label show-transport actions as "transport (play/record/stop...)" in case the user doesn't know what a transport is
