REAPER v7.24+dev1007
v7.24+dev1007 - October 7 2024
* Includes feature branch: batch converter updates
+ Actions: add actions to display toolbars as a menu at the mouse cursor
+ Automation points: fix slight drawing errors made obvious with large envelope points
+ Automation: fix various bugs for recording take FX automation
+ Batch converter: add "copy current settings to clipboard for command line use" to presets menu
+ Batch converter: adjust metadata preferred position for start padding
+ Batch converter: support saving output settings with presets (note that presets are shared with render settings)
+ Batch converter: use media item position in project when converting media items and preserving metadata start position
+ Batch converter: when preserving metadata preferred start position and converting media items, if the source media does not contain a preferred start position, use the media item position in the project
+ Batch converter: when trimming leading silence and writing metadata preferred position, adjust preferred position after trimming
+ FX: improve support for single-line or multi-line comments
+ Media explorer: properly sort positive values in the peak or loudness column [t=294622]
+ Metadata: support multi-line editing of multiple fields at the same time
+ Project tabs: hide/show FX comment window when switching project tabs [t=294657]
+ ReaLimit: fix rounding when using mousewheel on controls [t=294441]
+ ReaScript: dpcument gfx.mouse_cap modifier key flags for both Windows and macOS regardless of which OS the documentation is generated on
+ Recording: fix actions to add take marker at mouse position when mouse is over a currently-recording media item [t=294911]
+ Render: clicking on an already-selected rendered file in the list returns the display to "live" if still rendering [p=2813299]
+ Render: fix marker display with certain themes
+ Render: fix possibly incorrect rendered file when rendering with "preserve source media sample rate if possibe" enabled
+ Render: move actions to jump to first clip or loudest sample back to Stats/Charts menu (for accessibility)
+ Render: support normalizing/limiting/trimming to master mix, even when rendering tracks/items via master
+ Render: support rendering only new files, skipping existing files [t=294520]
+ Render: support trimming silence from start/end of rendered files
+ Render: when rendering razor edits or selected media items, parallel render any files that have start/end times aligned in the project
+ VST3: notify processor when controller performEdit a parameter and automation notifications are ignored
+ Wildcards: $track wildcard resolves to "Track 3" (for example) if the track is not named
+ Wildcards: deprecate $namenumber, use $filenumber or $recnumber instead
+ Wildcards: warn if the user enters a wildcard character in the directory field in the render or batch converter dialogs
+ Windows: fix JSFX spacebar behavior (v7.23 regression) [t=294908]
# Batch converter: fix $chid wildcard when providing channel names [p=2810996]
# Batch converter: fix trimming silence from end of file
# Render: disable common gain normalization and silence trimming for video renders
# Render: restore 'preserve source media sample rate if possible' checkbox
