v7.24+dev1010 - October 10 2024
* Includes feature branch: implode/explode support in batch converter
* Includes feature branch: trim leading/trailing silence in batch converter
* Includes feature branch: batch converter UI changes
+ FX: fix parameter linking being set incorrectly when adding/removing ReaEQ/ReaXcomp bands
+ Mouse modifiers: restore behavior of opening mouse modifiers preferences page to the last context that applied to a mouse edit
+ Parameter modulation: fix keyboard support with more than 2 windows open at once [p=2813584]
+ Razor edits: using the mouse modifier "add to razor edit area" with no already-existing razor edits will enclose any selected media items in razor edits
+ Render: add option to automatically reopen render dialog modelessly when first setting time selection or markers/regions from that window
+ Render: fix potential window movement when re-opening render window following completion [p=2814048]
+ Render: hide minimize box when render results window goes modeless
+ Render: rearrange buttons at bottom of render setup dialog
+ Rendering: fix leak at end of online renders
# Batch converter: fix saving normalize mode in presets
# Render: support render after dry run after reopening render dialog modelessly
