REAPER v7.25rc1
v7.25rc1 - October 11 2024
+ Color theme: allow theme to define empty arrange view area and empty arrange view area vertical shading colors that are identical [t=294982]
+ FX: fix parameter linking being set incorrectly when adding/removing ReaEQ/ReaXcomp bands
+ FX: fix potential deadlock when toggling bypass and in automation-write mode
+ Media explorer: properly sort positive values in the peak or loudness column [t=294622]
+ Parameter modulation: fix keyboard support with more than 2 windows open at once [p=2813584]
+ Project loading: fix potential lost sends when loading with certain FX [t=295006]
+ Project tabs: hide/show FX comment window when switching project tabs [t=294657]
+ ReaLimit: fix rounding when using mousewheel on controls [t=294441]
+ Recording: fix actions to add take marker at mouse position when mouse is over a currently-recording media item [t=294911]
+ Render: add option to automatically reopen render dialog modelessly when first setting time selection or markers/regions from that window
+ Render: add option to shade areas that do not contribute to LUFS-I [t=295076]
+ Render: after render, if there are not too many overs, support moving edit cursor from one over to the next
+ Render: automatically reopen render dialog modelessly after setting edit cursor position or time selection in render dialog
+ Render: clicking on an already-selected rendered file in the list returns the display to "live" if still rendering [p=2813299]
+ Render: fix marker display with certain themes
+ Render: fix potential window movement when re-opening render window following completion [p=2814048]
+ Render: hide minimize box when render results window goes modeless
+ Render: move actions to jump to first clip or loudest sample back to Stats/Charts menu (for accessibility)
+ Render: preserve render peaks preview time selection when switching between rendered files, resizing dialog, or reopening modelessly
+ Render: rearrange buttons at bottom of render setup dialog
+ Render: support automatically reopening render dialog modelessly when render finishes
+ Render: support defining a wildcard (like $project) as the master track substitution for the $track wildcard [?t=284551]
+ Render: use theme marker/region lane background colors in render peaks display
+ Render: when adding project markers/regions from render dialog, update render display and include the new markers/regions in HTML render statistics
+ Render: when reopening render dialog modelessly, preserve which rendered file is selected/displayed
+ Rendering: fix leak at end of online renders
+ Wildcards: warn if the user enters a wildcard character in the directory field in the render or batch converter dialogs
+ Windows: fix JSFX spacebar behavior (v7.23 regression) [t=294908]
# Render: always fit render listview columns to fit window
# Render: support render after dry run after reopening render dialog modelessly
