v7.25+dev1015 - October 15 2024
* Includes feature branch: media explorer ripple edit on keyboard insert
* Includes feature branch: implode/explode support in batch converter
* Includes feature branch: trim leading/trailing silence in batch converter
* Includes feature branch: batch converter UI changes
+ Automation: add preference to control whether volume/pan automation recording happens at processing position (what you hear) or playback position
+ Automation: volume/pan automation recording now defaults to what you hear rather than at playback position
+ Item ruler: display a label at time zero, but do not display labels for negative time
+ Media explorer: fix preview playback with 2x and 0.5x tempo-matching [t=295166]
+ Preferences: add render peaks display settings to stats/charts menu in Preferences/Audio/Rendering
+ Render: ensure ruler/tooltip color contrasts with background color for readability [t=295145]
+ Wildcards: fix $tracknumber wildcard when used on master track [t=295164]
# Render: fix render statistics calculation when applying brickwall limiter
