REAPER v7.26rc1
v7.26rc1 - October 23 2024
* Includes feature branch: media explorer ripple edit on keyboard insert
+ Accessibility: improve labels for Dynamic Split window
+ Accessibility: improve spacebar/tab support for transient-sensitivity window
+ Accessibility: improve tab order/labels for trim/remove silence window
+ Actions: add actions to display toolbars as a menu at the mouse cursor
+ Automation points: fix slight drawing errors made obvious with large envelope points
+ Click source: add checkbox to sample browse dialog to copy samples into project directory
+ Envelopes: click on selected point with no mouse move will deselect other points
+ Item ruler: display a label at time zero, but do not display labels for negative time
+ Marker/region manager: fix CSV import of marker/region indices
+ Marker/region manager: make CSV import more lenient of unknown columns
+ Media explorer: fix preview playback with 2x and 0.5x tempo-matching [t=295166]
+ Media explorer: obey ripple settings when inserting media via enter/context menu
+ Mouse modifiers: restore behavior of opening mouse modifiers preferences page to the last context that applied to a mouse edit
+ Mute/solo: do not send noteoffs to track FX immediately on mute/unsolo [t=291742]
+ Preferences: add render peaks display settings to stats/charts menu in Preferences/Audio/Rendering
+ ReaScript: InsertMedia/InsertMediaSection can optionally respect project ripple editing setting
+ Render: always reopen render dialog modelessly when render is complete, unless set to auto-close or auto-return to render settings
+ Render: ensure ruler/tooltip color contrasts with background color for readability [t=295145]
+ Render: improve speed when rendering very many files at once [t=295211]
+ Render: note that reopening modelessly causes the window to visibly close and reopen on Windows
+ Render: reopen render dialog modelessly after opening rendered file in Media Explorer (to allow focus to move to Media Explorer)
+ Render: support changing previewed file via listview keyboard navigation
+ Routing: add option to add sequential hardware outputs for selected tracks when right-clicking I/O button in TCP/MCP
+ System: automatically clear SSE exception flags for systems/plug-ins that leave exceptions in incorrect states
+ Track control panel: do not change track selection when clicking on TCP track resize divider [t=295079]
+ VST3: notify processor when controller performEdit a parameter and automation notifications are ignored
+ Wildcards: $region resolves to a matching region even if rendering between markers [t=295274]
+ Wildcards: add wildcards for length in hours, minutes, seconds, milliseconds [t=295298]
+ Wildcards: fix $tracknumber wildcard when used on master track [t=295164]
# Render: disable mouseover until render is finished
# Render: fix "file X of Y" display when rendering via master
# Render: fix peaks display when render finishes and normalizing via master mix
# Render: fix render peaks display temporarily going blank after normalizing to master mix
# Render: restore render window title bar text when reopening modelessly
# Render: support back button after reopening render dialog modelessly
