v7.26+dev1030 - October 30 2024
* Includes feature branch: MIDI editor CC point scaling
* Includes feature branch: automation timing and take FX fixes
* Includes feature branch: implode/explode support in batch converter
* Includes feature branch: trim leading/trailing silence in batch converter
* Includes feature branch: batch converter UI changes
+ Actions: fix dry run render time display in actions to calculate media item loudness
+ Crossfade editor: support spectral or loudness peaks display
+ FX browser: fix resize issues when using high DPI scaling values
+ Peaks: correct LUFS graph display of fadeouts when displaying LUFS and spectral peaks
+ VST3: fix incorrect preset state-loading for UADx plug-ins
+ Windows: arm64 installer uses default Program Files directory rather than old (Arm) path
# Crossfade editor: fix peaks display not responding to changes in fade-out shape
# Crossfade editor: support right-click anywhere in the crossfaded area to change fade shape
# ReaScript: GetSetProjectInfo_String("RENDER_STATS") automatically enables preference to store completed render statistics in memory if run with an action ID, warns the user about the setting otherwise [p=2818742]
