v7.27 - November 1 2024
+ Actions: add action to dry run render project, using the most recent render settings
+ Actions: fix dry run render time display in actions to calculate media item loudness
+ CLAP: improve splash screen status display when scanning plug-ins
+ Click source: fix copying of samples to project path when configured and the ClickSamples folder does not yet exist
+ Click source: obey user-selected copy-to-project-directory option regardless of global/project setting
+ Envelopes: fix potential use after free when pasting envelope points and last-selected envelope no longer exists
+ FX browser: fix resize issues when using high DPI scaling values
+ Menu/toolbar editor: fix cutting multiple items near end of list
+ Peaks: correct LUFS graph display of fadeouts when displaying both LUFS and spectral peaks
+ Render: add preference to prevent render window from reopening modelessly after render finishes [p=2818237]
+ Render: fix normalizing to master mix when also rendering master mix (7.22 regression)
+ Ripple editing: fix potentially-incorrect crossfade on rippled items when trim-behind enabled
+ Take markers: snapping properly ignores take markers outside of item bounds [p=2817850]
+ VST: fix incorrect preset state-loading for UADx VST3 plug-ins (7.26 regression)
+ VST: improve preset menu behavior with duplicate factory and user-preset names
+ VST: improve support for TrackFX_GetPresetName on FX with a single program [t=295339]
+ Web interface: allow adding extra HTTP headers via reaper.ini [csurf_www] header1=name:value header2= etc [t=216538]
+ Windows: improve arm64ec installer (use correct modern Program Files path, label shortcuts as arm64)
