REAPER v7.27+dev1103
v7.27+dev1103 - November 3 2024
* Includes feature branch: MIDI editor CC point scaling
* Includes feature branch: automation timing and take FX fixes
* Includes feature branch: implode/explode support in batch converter
* Includes feature branch: trim leading/trailing silence in batch converter
* Includes feature branch: batch converter UI changes
+ Crossfade editor: add context menu option to auto-center after mouse edits
+ Crossfade editor: add theme images for navigation buttons
+ Crossfade editor: draw very short-term combined loudness graph
+ Crossfade editor: hold alt/opt key while editing crossfade intersection handle to keep left-right movement minimal
+ Crossfade editor: support docking
+ Crossfade editor: support double-click to reset fade curvature or item volume
+ Crossfade editor: support editing item volume
+ Crossfade editor: support vertical peaks zoom
+ Crossfades: allow changing either fade-in/out or crossfade shape via fade shape popup menu
+ Main menu: make recordings settings menu actions a bit more accessible via left click on Windows/Linux
+ Project save: improve handling of very long project file names
+ ReaScript: ShowConsoleMsg() Supports !SHOWERR: to go with !SHOW:, displays indicator in menu bar when latent messages are waiting
+ ReaScript: add option to never auto-show ReaScript Console
+ Render: enable dual mono normalization setting by default, add more help for the setting
# Crossfade editor: fix multichannel peaks display
# Crossfade editor: fix scaling for transport buttons
# Crossfade editor: improve positioning of crossfade intersection handle
# Crossfade editor: respect shift key to toggle link when right-clicking to change fade shape
# Crossfade editor: support separate preroll/postroll
# Preferences: fix persistence of some rendering settings
