v7.27+dev1129 - November 29 2024
* Includes feature branch: ripple edit when editing media item edges
* Includes feature branch: MIDI item reconfiguration on effective timebase change
* Includes feature branch: phase alignment dialog
* Includes feature branch: per-lane ripple editing
* Includes feature branch: auto-filter CC for MPE
* Includes feature branch: MIDI editor CC point scaling
* Includes feature branch: automation timing and take FX fixes
* Includes feature branch: implode/explode support in batch converter
* Includes feature branch: trim leading/trailing silence in batch converter
* Includes feature branch: batch converter UI changes
+ Media item properties: support entering take start in source in samples, if all selected items have the same sample rate
+ Ripple: fix ripple-all potentially affecting automation too early on non-edited tracks
+ Ripple: fix ripple-all potentially affecting automation too early on non-edited tracks [p=2825443]
# Crossfade editor: fix display when stretch markers exist
# MIDI: treat timebase of beats (position only) as normal for MIDI items, do not set them to fixed tempo in response
# MIDI: when inserting multitrack midi to track that has timebase set and adding tracks, inherit track timebase
# Phase aligner: more responsive auto-updating alignment calculation/display
# Ripple: improve behavior when rippling media item right edge
