FX Device --一个类似ableton live和bitwig的底部参数调制控制栏
这个脚本工具感觉还是蛮方便的哈,除了参数调制外,还可以自己制作旋钮之类的:
FX Device
This script is now available in ReaPack
Features:
  • Container Modulators (updated Aug 6 2024)
each container can now have its own set of modulators:
  • Macro modulation
  • Envelope Modulation
  • Preset Morphing
  • Change Modulation type
  • FX layering
Allows up to 8 channels of parallel processing, simply drag and drop fxs to assign them to the right channels.
Ctrl-Click: Rename channel Alt-Click: Delete Channel Double Click: Reset to default value
  • Band Splitter
You can add FXs that would only affect a certain frequency range.
  • Pre/Post FX Chain
Drag FX to edges to put them in Pre/Post chain, FXs in Pre/Post chain will stay in the beginning/end of the chain.
  • Layout Editor
You can create custom UIs without coding:
Installation:
add this to your reapack: https://raw.githubusercontent.com/Br...main/index.xml
Requirement to run:
From reapack:
Ultraschall by Meo-Ada Mespotine: https://github.com/Ultraschall/ultra..._api_index.xml
js_ReaScriptAPI by juliansader: https://github.com/ReaTeam/Extension...ster/index.xml
ReaImGui by cfillion - Available in ReaPack by default.
看着很棒多谢
BryanChi_FX Devices.lua:43: ImGui__init: ReaImGui 0.9.2 is too old (action requires API 0.9.3 or newer)
我装了它 依赖的几个reapack,运行 的时候依然报错了,请问是什么原因呢,我该怎么解决呢
提示说的是你装的realmGui的版本过旧,升级下新的就可以了
dependency 解决了。现在,可是为啥我出来的是空的框框呢?
点击控制栏中的插件条会弹出该效果器的相关参数,手动添加自己想要控制的参数;或者打开效果器窗口,动一下想要控制的参数按钮之类的,然后点击FX device窗口左上角的那个加号
先码住,等更新版本后装,谢谢
ableton转过来的人狂喜
