REAPER v7.34rc2
v7.34rc2 - February 25 2025
* Includes feature branch: improved VST2/VST3 migration
* Includes feature branch: spectral edit api
* Includes feature branch: support formatting suffix used when automatically incrementing rendered files
* Includes feature branch: support disabling ARA for specific plugins
+ Localization: add option to show control IDs in debug tooltip
+ Localization: improve window auto-size-increasing behavior
+ Localization: prevent fresh of prefs-help via holding alt+shift, allowing localization-tooltips to display
+ Localization: reduce debug-tooltip delay
+ Localization: support better expansion logic via auto_expand keyword on 5CA1E lines
+ Localization: support for per-control scaling via 5CA1E lines, using the syntax =1 1 @ctl_id=scale ...
+ Tempo: fix action to apply playrate to tempo when tempo basis is not 1/4 [t=298732]
# Localization: fix localization of scaled items
# Localization: improve auto-expansion logic
# PDC auto-bypass: update UI to reflect auto-bypass state
