v7.34+dev0303 - March 3 2025
* Includes feature branch: themeable track gain reduction meters
* Includes feature branch: actions to save and restore envelope latches
* Includes feature branch: region editing preview display changes
* Includes feature branch: region/marker lanes
* Includes feature branch: MIDI overhaul, aftertouch/MPE-CC-autofilter, tweaks
* Includes feature branch: parallel render via master
* Includes feature branch: multithreaded render postprocessing
* Includes feature branch: optionally display recording pass, markers, regions, wildcards in Big Clock
* Includes feature branch: render all selected items or razor edit areas as a single file
* Includes feature branch: ripple edit when editing media item edges
* Includes feature branch: MIDI item reconfiguration on effective timebase change
* Includes feature branch: phase alignment dialog
* Includes feature branch: per-lane ripple editing
+ API: get_config_var() can query active langpack with __langpack_filename
+ ARA: fix possible crash when splitting media items (7.30 regression) [t=297382]
+ Defaults: do not show mixer by default
+ Defaults: show master track by default
+ FX: pin mappers respect advanced preference to remain open if desired
+ File types: support .mka (Matroska Audio Container) files if the encoder is found
+ Media item take channel mapper: detect when item selection changes and update window
+ Theme: if transport_basis_quarter, etc images exist, display that image's hover/click state when tapping tempo
# Ruler: improve stability of lane height when adding and removing lanes
