v7.34+dev0310 - March 10 2025
* Includes feature branch: pin tracks in TCP
* Includes feature branch: themeable track gain reduction meters
* Includes feature branch: actions to save and restore envelope latches
* Includes feature branch: region editing preview display changes
* Includes feature branch: region/marker lanes
* Includes feature branch: MIDI overhaul, aftertouch/MPE-CC-autofilter, tweaks
* Includes feature branch: parallel render via master
* Includes feature branch: multithreaded render postprocessing
* Includes feature branch: optionally display recording pass, markers, regions, wildcards in Big Clock
* Includes feature branch: render all selected items or razor edit areas as a single file
* Includes feature branch: ripple edit when editing media item edges
* Includes feature branch: MIDI item reconfiguration on effective timebase change
* Includes feature branch: phase alignment dialog
* Includes feature branch: per-lane ripple editing
+ Media explorer: support previewing m4a and other video-supporting container formats through a track if the file contains no video stream [t=297260]
+ Render: add info button to explain risks of enabling parallel render via master
+ Render: fix behavior of setting to render tracks with only mono media to mono files when track has media with mixed channel counts [t=299005]
+ Track panels: display some helpful text in the empty TCP area if no tracks exist
# Crossfade editor: fix behavior when locking left-hand item start
# Defaults: revert empty projects defaulting to a single track
# Render: parallel render via master is opt-in, rather than opt-out
# Track pinning: avoid unintentionally marquee-selecting items that are scrolled slightly out of sight [p=2852386]
# Track pinning: fix auto-scroll when running action to select previous/next track
# Track pinning: fix display after undoing track pin
# Track pinning: improve behavior when vertically zooming pinned tracks
# Track pinning: improve zoom/scroll behavior after adding tracks
