v6.46 - January 19 2022
+ Automation: fix potential incorrect automation when envelopes disabled outside of automation items [t=240584]
+ Batch converter: fix normalization (6.44 regression) [t=262025]
+ Batch converter: resolve item-related wildcards properly when converting a media item that originated in a different project [t=261724]
+ Control surfaces: fix OSC control of FX wet/dry knob [t=261531]
+ FX: add actions to clear delta solo for all FX on selected tracks or all FX in the project
+ Import: add cancel button to multiple media item import dialog
+ JSFX: fix set_pin_mapping() high-bit issue
+ macOS: fix arrow key keyboard navigation issues for various windows (6.43 regression)
+ macOS: fix keyboard focus after closing transport selection/bpm edit boxes
+ macOS: improve appearance of routing matrix in dark mode and default theme
+ Media items: fix adjusting media to tempo suggested by filename or metadata when inserting via action
+ Media items: add actions to normalize items to common gain, or separately, using most recent settings
+ Media items: show warning or error (depending on context) when some items could not be normalized
+ Metadata: add ASWG dialogue projection level field
+ Metadata: add OGG, Opus to displayed list of render formats that support Vorbis metadata
+ Metronome: fix count-in issue at 180bpm 3/4 [t=261495]
+ MIDI: add actions to reload track support data (bank/program files, notation, etc) for individual MIDI items or all items in the project [t=261642]
+ MIDI editor: improve scroll behavior when adjusting zoom [t=254669]
+ MIDI editor: improve zoom to content action behavior [t=261214]
+ MIDI inline editor: improve default note view sizing
+ mp3: close .reapindex files when media is set offline [t=261537]
+ ReaScript: Lua built-in print() function output is visible using DebugView on Windows [t=261902]
+ ReaScript: fix incorrect fuzzy matching in TrackFX_AddByName() etc [t=261799]
+ ReaScript: improve gfx_blit() documentation [t=261610]
+ RS5k: fix incorrect resampling at end of sample (most obvious with r8brain free)
+ Theme: fix layout actions for single-character layout names [t=234937]
+ Tracks: if tracks are removed while renaming a track in TCP/MCP, close edit field
+ VST: do not allow scanning root directories on macOS/linux (revert 6.44 change) [p=2514467]
+ WavPack: fix incorrect truncation in 16-bit mode [t=261535]
+ Windows: fix DirectX plug-in preset menu
+ Windows: fix new VST path addition on 64-bit
