REAPER v7.35+dev0326
v7.35+dev0326 - March 26 2025
* Includes feature branch: pin tracks in TCP
* Includes feature branch: themeable track gain reduction meters
* Includes feature branch: region editing preview display changes
* Includes feature branch: region/marker lanes
* Includes feature branch: MIDI overhaul, aftertouch/MPE-CC-autofilter, tweaks
* Includes feature branch: parallel render via master
* Includes feature branch: multithreaded render postprocessing
* Includes feature branch: optionally display recording pass, markers, regions, wildcards in Big Clock
* Includes feature branch: render all selected items or razor edit areas as a single file
* Includes feature branch: MIDI item reconfiguration on effective timebase change
* Includes feature branch: phase alignment dialog
+ Actions: update last used media directory after importing multiple files at once [p=2855495]
+ Automation items: fix bad behavior when copying media items with 'move envelope points with media items' and ripple edit both enabled
+ CLAP: fix MIDI editor CC lane names being cleared when using CLAP instrument FX [t=299341]
+ Pin connection window: fix position when respawning due to FX I/O change (7.35 regression)
+ Track pinning: add action to show/hide all pinned tracks
+ Track pinning: support theme images for pinned track divider (tcp_pinned_divider, tcp_pinned_divider_overflow)
# Debug: arrange_perf includes more info
# Track pinning: do not change height of unpinned tracks when moving pinned area divider
# Track pinning: fix display when 'allow editing media while comping' is enabled
# Track pinning: turn off track pin override when running actions to pin/unpin tracks
