REAPER v6.50
v6.50 - March 3 2022
+ API: allow accelerators to hook keyboard for more windows including mixer, navigator, etc [t=263487]
+ Batch converter: support converting multiple files in parallel, utilizing multiple CPUs
+ Batch converter: improve responsiveness and RAM usage when converting a large file list
+ Batch converter: display the number of files and directories in the file list
+ Batch converter: display progress bar if conversion takes more than a short time
+ Batch converter: add when adding directory to file list, prompt to include subdirectories as well
+ Batch converter: add option to use source subdirectory structure to create output directories
+ Batch converter: add option to overwrite original files
+ Batch converter: add option to suppress notification when finished
+ Batch converter: add “save settings” button (does not save file list)
+ Batch converter: reorganize controls to separate settings that are not included in presets
+ Batch converter: include dither, noise shaping settings with presets
+ Batch converter: add preset menu item to clear all converter settings
+ Batch converter: add context menu actions to fit file list columns to screen, open input or output path, display input media properties
+ Batch converter: after canceled conversion, convert and remove buttons offer to affect only converted/not-yet-converted files, or all files
+ Batch converter: change default output file pattern to “$source-converted”
+ Batch converter: delete incomplete output file on user cancel
+ Batch converter: don’t embed project-specific metadata
+ Batch converter: preserve very long metadata correctly
+ Batch converter: support $track, $tracknumber, $itemnumber wildcards, which will resolve to the project state at the time the media item was added to the file list [t=262781]
+ Batch converter: update $samplerate wildcard correctly when changing sample rate
+ Batch converter: allow FX to change processing channel count via pin connector dialog or JSFX channel mapper/downmixer
+ Batch converter: fix lost FX tail setting when closing/reopening dialog
+ Defaults: set default master track pan mode to stereo balance for new projects
+ Defaults: save/load master track pan law, pan mode with default project settings
+ FX: allow JSFX channel mapper/downmixer to change monitoring FX processing channel count
+ FX: improve behavior of FX drag/drop and TrackFX_CopyToTrack() etc when copying FX to a later slot on the same chain [t=263461]
+ FX: fix incorrect project save/load of parameter modulation and linking when applied to ReaPlugs (6.48 regression)
+ Media: improve zoomed-in peaks performance, especially on compressed media
+ Media: improve performance when using large block sizes and small media buffer settings
+ Media explorer: fix peaks display build restarting when seeking with output routed to a track [p=2532186]
+ Media explorer: improve seek behavior when autoplay, start-on-bar, and tempo matching are all enabled
+ Media explorer: refresh display correctly after completing search [t=245536]
+ MIDI: do not remove duplicate note on/off events on import [p=2527130]
+ MIDI: send note-off for active notes when seeking [t=260429]
+ MIDI: fix incorrect event duplication when exploding certain MIDI content by channel [t=261174]
+ MIDI: improve tick-to-sample rounding
+ Mouse modifiers: display and group media item lower half actions similarly to media item actions in preferences dropdown
+ ReaScript/JSFX: fix displaying strings containing multiple newlines in a row [t=263537]
+ Render: ensure peaks display is fully updated for each rendered region
+ Render: fix enabling/disabling render loudness statistics from completed render dialog
+ Undo: ensure undo point is created after running action to remove content behind items [t=263577]
+ VST: report channel index namespace context to plugins [t=263201]
+ VST: fix some misbehaving UI sizing plugins [p=2531463]
