卧室制作人博客:Get 70% OFF KV331 Audio Synthmaster 2.9 @ Audio Plugin Deals
Audio Plugin Deals lets you get the Synthmaster 2.9 virtual synthesizer for only $29.90 (instead of $99). That’s a massive 70% discount! The offer is valid till March 30th, 2022.
Synthmaster 2.9 by KV331 Audio is a versatile and semi-modular synth plugin. Available in the VST, AU, and AAX formats for macOS and Windows, the synth has a host of powerful features and an extensive library of presets.
Synthmaster provides an option to control just about every aspect of your sound. The controls are not limited to a one-dimensional approach like turning a knob; everything from ADSR to LFO is controlled using intuitive graphs.
You can apply a complex modulation to every parameter, and there are multi-algorithmic oscillators, flexible effects routing, and zero-delay feedback filters.
The arpeggiator features Up, Down, DownUp, UpDown, DownUp2, UpDown2, Sequence, Chord, Argeggiate, and AsPlayed modes. The arpeggiator has 32 steps, each with its own velocity, note length, note number, hold, and slide values, making it very customizable.
Along with the 1,850 factory presets and 32 preset expansion banks, Synthmaster allows you to access hundreds of online presets created by other registered users and upload your own presets. This makes it easy to share and use particular settings and find inspiration, making your overall workflow quick and smooth.
You can also import WAV and AIFF multisample files as SFZ definitions. All you have to do to import sounds is drag and drop the files in the oscillator waveform view in the plugin window.
These features make it possible to personalize your synths completely using Synthmaster’s robust framework.
The UI is also customizable, with three different skins. Each skin comes in a range of colors for you to choose from. And if that’s not enough for you, you can create your own skins to suit your taste.
A free demo also allows you to test the synth for 30 minutes (albeit with fewer factory presets). You can find it on KV331’s official website.
Synthmaster has consistently been one of the best synth plugins for several years. This is undoubtedly a deal worth considering at a fraction of the price. It offers a robust feature set, a well-designed user interface, and many presets to help new users get started.
Synthmaster 2.9 (70% OFF @ Audio Plugin Deals)
资讯出处:Get 70% OFF KV331 Audio Synthmaster 2.9 @ Audio Plugin Deals - Bedroom Producers Blog
