v6.52 - March 23 2022
+ Actions window: match UK spellings of various words when searching
+ Automation items: when looping in latch mode, ensure there is an automation item to record into [t=263124]
+ Batch converter: add option to force single-threaded processing
+ Batch converter: fix minimum window size when Windows display scaling is used [t=264256]
+ Custom menus: fix menu after reset to default on macOS
+ FLAC: update to libflac 1.3.4
+ FX: fix display of ReaLearn UI on macOS
+ JSFX: fix channel mapper/downmixer text alignment on non-retina macOS displays
+ macOS: improve default extension behavior of save dialog on newer macOS systems [p=2538902]
+ Media Explorer: add option, toolbar button to display detected pitch while previewing files
+ Media Explorer: add actions, option to adjust pitch by +/- 1 cent
+ Media Explorer: support toolbar/menu feedback for actions to set pitch to X semitones
+ Media Explorer: shift+drag applies the previously selected pitch knob behavior (rather than always applying either continuous or semitone changes)
+ Media Explorer: improve transition smoothness when adjusting preview pitch via actions
+ Media Explorer: add preference to preview .RPP files
+ Media Explorer: add preference to suppress auto-render of proxy when previewing .RPP files [t=260947]
+ Media Explorer: when renaming .RPP file, also rename matching .RPP-PROX file [t=263798]
+ Media Explorer: fix context menu issues when media explorer is opened via keystroke
+ MIDI editor: add actions, menu items to load/unload .ReaScale files
+ MIDI peaks: fix under-draw issue in continuous scrolling [twtr=1499242508328443904]
+ Notation editor: action to identify chords considers all notes playing, not just notes that start at the target time position [t=263540]
+ Notation editor: allow user-provided chords (from .ReaScale files) to override default chord names [p=2534376]
+ Notation editor: don't show track/measure settings menu on left-click [t=238093]
+ Notation editor: treat click on measure start area as a click on the first beat of the measure, even if there is a key signature or time signature change
+ Opus: fix memory leak when writing files and resampling
+ PCM: extremely minor tweaks to rounding when writing PCM in all formats
+ PCM: improve LSB rounding when writing 24-bit and (17-23)/24-bit encodings of WavPack/FLAC [t=263082]
+ PCM: fix incorrect truncation when writing 16-bit WavPack files [t=261535]
+ Peaks building: display remaining file statistics rather than remaining items
+ Peaks building: improve behavior when reordering tracks/items
+ Peaks building: improve multiprocessing use (4 or more cores when available)
+ Peaks building: optimize spectral peaks/spectrogram calculation
+ Project settings: add dropdown menu to support setting/resetting project start offset and project start measure
+ ReaFIR: add automatable parameter to adjust gain of EQ/threshold/noise profile curve
+ ReaPlugs: show longer, more descriptive parameter names
+ Render: add action to re-display statistics from most recent render in web browser
+ Render: add option to display/not display RMS in render statistics
+ Render: add option to automatically return to render setup window when render is finished [t=264054]
+ Render: enable "save settings" button when changing render tail setting
+ Render: ensure progress bar and stats are updated after rendering very short regions
+ Render: gray out add-metadata button when "embed metadata" is unchecked
+ Render: greatly improve render speed when rendering many regions at once
+ Render: avoid extra work relating to updating status in dock on macOS
+ Text drawing: fix cropped glyphs for some fonts/italics combinations [t=262915]
+ Theming: in themes that overlap controls and track icons, draw track icons below controls
+ Wildcards: support $channels wildcard in render, batch converter, and bounce
+ Windows: add legacy_filebrowse=1 .ini file option to use old file browsing open/save API for accessibility purposes
