REAPER v7.52+dev1104
v7.52+dev1104 - November 4 2025
* Includes feature branch: simplify tempo match preferences
* Includes feature branch: mixer FX/send slots
* Includes feature branch: optionally bring plugins online one at a time after loading project
* Includes feature branch: multi-mono/multi-stereo FX containers
* Includes feature branch: UTF-8 corner case improvements
* Includes feature branch: improved ruler lane and media item locking
* Includes feature branch: display project loading progress
* Includes feature branch: recursively import system folders to folder tracks
* Includes feature branch: optional fade-in/fade-out in Media Explorer
* Includes feature branch: spectrogram and spectral editing improvements
* Includes feature branch: additional options when importing system folders
* Includes feature branch: Console1 control surface support
* Includes feature branch: render to per-channel mono files
* Includes feature branch: per-take sample edit envelopes
* Includes feature branch: support for tcp_infoblock theme images
* Includes feature branch: region editing preview display changes
* Includes feature branch: region/marker lanes
+ Actions: fix potentially extra MIDI events being added to apply track FX as new take with MIDI output
+ Automation items: add project setting to choose whether Beats (position only) changes length of automation items (on by default, matching behavior of 7.49 and earlier)
+ Automation items: fix start offsets when switching timebases
+ Default theme: update send level meter images slightly
+ Drag and drop: ignore .txt files when accidentally dropped in with other media
+ Fades: improve behavior of 'move crossfade' mouse modifier when editing non-crossfade [t=304426]
+ MIDI editor: show note names from tracks that MIDI is routed to, if any
+ Media import: don't prompt to match empty project tempo to media if the project tempo is already set to the media tempo
+ Portable installs: fix issue in new 7.50 feature where VSTs would be rescanned even if skip requested by user
+ REX: fix potential error when importing as beat slices and source tempo is lower than project tempo [t=304388]
+ REX: when importing as beat slices from media explorer with time selection set, import slices if they start within the time selection, and do not truncate the end of the slices
+ ReaScript: update GetThingFromPoint() to return item hit for tcp.sendlist etc
# FX slots: improve behavior when dragging over existing slot
# Slots: actions to toggle UI for FX #1-#8 respect slottings
# Slots: actions to toggle send mute #1-#8 respect slottings
# Slots: better interaction with ARA plug-ins (prevent them from being put in other slots etc)
# Slots: fix some incorrect updates of send slots via API and/or drag-drop
# Slots: make tcp.sendlist slot-aware for mousedrags
