Plugin Boutique’s massive 89% OFF sale on the Solid State Logic Native Essentials Bundle expires in less than 24 hours.
The good news is that the Solid State Logic Native Essentials Bundle is currently available for only $49.99 (that’s 89% OFF its regular $479 price). The bad news is that the deal expires on May 1st, so there are less than 24 hours left to get this incredible discount.
The bundle contains a pair of Solid State Logic plugins that promise to deliver a console-like mixing experience within the comfort of your DAW.
The first is the SSL Native Channel Strip 2, a console-style channel strip with filtering, EQ, compression, etc. The components are modeled after the SSL 9000K console channel strip.
“The SSL Native Channel Strip 2 Plug-in delivers the legendary tone, features, and workflow of an SSL 9000K console channel strip, now featuring SSL’s proprietary ‘Anti-Cramping’ technology and external Side Chain input.”
The bundle also includes the SSL Native Bus Compressor 2 which is designed to “glue” the stereo bus channels in your DAW.
“Few pieces of gear are as universally revered as the SSL G-Series center section bus compressor, and now it’s available as an SSL-designed native plug-in. Celebrated for its ability to glue a mix together to make it “sound like a record,” the SSL Bus Compressor has a distinctly musical response that retains the dynamic integrity of a mix even at higher compression ratios.”
If you’re interested in adding a Solid State Logic plugin to your mixing and mastering arsenal, hurry up because this deal expires on May 1st.
On a related note, Loopcloud is currently running its biggest-ever sale. You can get a subscription for 50% OFF the regular prices.
Solid State Logic Native Essentials Bundle(deal expires on May 1st!)
资讯出处:Get 89% OFF SSL Native Essentials Bundle (Ends May 1st) - Bedroom Producers Blog
