卧室制作人博客:Harrison Consoles AVA Mastering EQ Is FREE For A Limited Time!
AVA Mastering EQ by Harrison Consoles is FREE at Plugin Boutique for a limited time.
The Harrison Consoles AVA Mastering EQ plugin has a list price of €93, and it’s available entirely free until June 9th, 2022. It is a full-range EQ with 31 control bands that range from 20Hz to 20kHz.
The special design of the bands lets you draw a flat line across adjacent frequencies. This design makes it easy to boost or cut wide ranges without sounding forced or unnatural.
The plugin has a +/-4dB scale by default, but if you move beyond 4dB, the scale will adjust to follow your movement (up to +/-14dB).
The intuitive and responsive GUI makes this plugin a flexible EQ that turns subtle or dramatic changes into a simple task.
The user-friendly GUI allows you to draw accurate EQ curves quickly. You can draw your EQ curve freehand as you can on many other plugins, but an excellent smooth function helps you tidy up any stray points. It’s easy to clear and start over if need be, too.
Harrison Consoles say AVA Mastering EQ makes it easy to recreate classic tones like Pultec, Tilt, and Baxandall.
The EQ has high-pass and low-pass filters with a selectable slope between 6dB/octave and 12dB/octave. It also features a 15dB Trim.
You’ll notice a little ear icon at the top right corner of the GUI, which is a momentary bypass switch that activates when held until let go. Next to it, you’ll see a gear icon that opens up a menu of interface options like resizing and theme selection.
We see a lot of freebies at Plugin Boutique, and this one couldn’t be simpler. It’s not a buy one get it free deal; it’s just free, no strings at all. Add the plugin to your cart at zero cost, checkout, and it’s yours.
Huge thanks to Plugin Boutique and Harrison Consoles for the freebie!
If you missed out on April’s freebies, you could make up for it by grabbing Antares DUO, too – FREE with any purchase at Plugin Boutique throughout May.
AVA Mastering EQ is available in AU, VST2, VST3, and AAX formats for macOS (10.7 upwards) and Windows (7 upwards).
AVA Mastering EQ (FREE until June 9th, 2022)
资讯出处:Harrison Consoles AVA Mastering EQ Is FREE For A Limited Time! - Bedroom Producers Blog
