v6.58+dev0519 - May 19 2022
+ FX: add compatibility setting to VST/AU/LV2 to use automatic tail detection, allowing plug-ins to opt-in to project setting
+ FX: add compatibility setting to ignore tail length
+ FX: add oversample options to floating FX window context menu
+ FX: add project setting to auto-bypass all plug-ins that report tail length, with user-defined silence threshold
+ MIDI editor: add undo points when changing time selection via alt+right drag [t=266591]
+ MIDI: fix looped playback issues with multiple simulaneous note-ons
+ Media explorer: add loudness column, populate peak volume and loudness after running action to calculate loudness
+ Media explorer: add option to normalize preview volume to -12LU if loudness has been calculated
+ Media explorer: when normalizing preview volume for loudness, adjust playback volume for mono media because preview is stereo
+ Peaks drawing: more precise peaks drawing at razor edit edges during mouse edits
+ Razor edits: improve video preview display when editing [t=264785]
+ Render: default to .mp4 extension (rather than .m4vwhen rendering mpeg-4) video
+ Render: improve normalization speed when rendering mp4/m4a containing audio stream only
+ Theme: minor adjustments to muted/unsoloed track/item overlay color and mode
+ Video: simplify WMF encoding settings
+ WALTER: fix corner case of parsing .] [t=266668]
+ WALTER: treat ‘scalar==vector’ in comparisons as ‘scalar==vector{0}’ rather than ‘scalar==0’ [p=2557841]
# Razor edits: when moving a razor edit, preview video at the start of the razor edit, not the start of the first item in the razor edit
