v6.60 - June 8 2022
+ API: extend hwnd_info hook API to allow disabling global hotkeys for a particular context
+ Crossfade editor: fix grouped item editing behavior when editor is open [t=266599]
+ Envelopes: fix incorrect envelope edit when moving media items across tracks with ripple-all enabled and moving envelope points with media items [t=267039]
+ FX: allow resizing FX windows beyond screen size on Windows
+ FX: improve automation-recording behavior with PDC when set to stop at end of time selection [p=2562770]
+ Grouping: when splitting grouped items, group all items that start at effectively the same time as the split point, rather than items that start after the split point [t=264639]
+ macOS: disable automatic key equivalent localization on macOS 12.0+
+ Media explorer: new user-added columns default to "custom" rather than "read-only" [t=267357]
+ MIDI: fix looped playback issues with partial blocks and multiple simultaneous note-ons
+ MIDI: if notation option "key signature changes affect all tracks" is enabled, embed key signature changes when exporting type 1 MIDI files [t=264803]
+ Mouse modifiers: fix enabling/disabling snap modifier during drag while creating marquee or razor edit area [p=2567049]
+ ReaFIR: clamp manually-edited point gain to graph range [t=267449]
+ ReaPlugs: improve end-of-touch automation support when tweaking sliders with keyboard/mousewheel
+ Recording: add per-track setting to record track output pre-FX or post-FX/pre-fader
+ Render: fix HTML render charts when files/markers/regions contain some special characters [t=267349]
+ Render: slight memory use improvement when resampling during render
+ Splash: improve status messages when loading FX [t=155245]
+ Splash: add option to skip splash screen animations on startup
+ Video: optimize opening of extra pooled audio decoders (do not try decode modes that previously failed)
+ Video: improve video preview display when using various edit modes [t=264785] [p=2566992]
+ Video: improve WMF decoding compatibility [t=267260]
+ Video: work around WMF bug when decoding certain files, by falling back to other decoders [t=266959]
+ VST: automatically end touch automation recording if configuration window is closed
+ VST: improve plug-in scanning process (especially macOS NI plug-ins)
+ WALTER: using front for mcp.extmixer now brings extmixer background higher in the Z-order
+ Windows: fix issue when rapidly clicking new project tab toolbar button [t=267507]
