v6.64 - July 13 2022
+ Batch converter: allow window to be resized to a smaller minimum height
+ GIF: fix memory leak when decoding files that have per-frame color maps
+ GIF: reduce memory use when decoding gif files with many frames
+ Help menu: sort documentation menu by filename [t=268485]
+ JSFX: set undo point after calling set_pinmapper_flags()
+ JSFX: sstillwell/randomizer supports 0x90 velocity=0 note-offs [p=2575240]
+ JSFX: support automating and undo for user mix volume sliders in channel mapper plugin [t=266268]
+ Master track: fix loudness meter readout tooltip
+ Media explorer: add loudness column, loudness calculation
+ Media explorer: add option to normalize preview volume to -12LU (adjusted for mono media if needed) if loudness has been calculated
+ Media explorer: add separate actions to calculate peak volume, loudness, or dry run statistics
+ Normalization: respect take channel mode when normalizing media items to target loudness [t=268290]
+ ReaScript: add CalcMediaSrcLoudness function
+ Region manager: sort take markers in project time order
+ Region manager: support selecting marker/region by name by typing in list view on Windows [t=268219]
+ Render: add menu item/action to display HTML render statistics with file paths hidden [t=268031]
+ Render: display project title and author in HTML render statistics, if they are set
+ Render: display RMS-RA (RMS-based dynamic range) measurement when LRA (LUFS-based dynamic range) is not calculated
+ Render: if no render file name is saved with the project, command line and queued renders use the project name as the output filename [t=258746]
+ Render: re-enable bounds dropdown if needed after loading render preset [t=268430]
+ Render: simplify loudness statistic preferences
+ Render: improve render statistics calculation CPU usage
+ Render: support fade-in/fade-out length, shapes
+ Resampling: fix r8brain-free hang when used with invalid samplerates [t=268643]
+ Theme: improve rounding for knob stacks [p=2575187]
+ Wave64: fix writing of floating point Wave64 files that lack channel ordering information (6.62 regression)
+ Windows: restore 6.61 alt-key behavior (to be revisited) [p=2577622]
