v6.64+dev0804 - August 4 2022
+ FX: improve syncing displayed value in generic UI [p=2583032]
+ MIDI: add action for retroactive record
+ PCM: support importing .pcm, drag-importing .raw audio files
+ SD2: support reading/playing back/converting .sd2 and other raw audio files, with limited support for specifying audio attributes (see .sd2 source properties)
# CLAP: add %CLAP_PATH% support for path list, default
# CLAP: always show menu when clicking re-scan button, to allow clear cache+rescan
# CLAP: apply path changes when re-scanning plug-ins
# CLAP: fix display of parameters in generic UI [p=2583166]
# CLAP: if vst_scan=1 (or =3) in reaper.ini, use in-process scanning
# CLAP: properly handle MIDI note-offs encoded as note-on with velocity zero
# CLAP: support category and developer listing in Add FX dialog (requires re-scan, also the first exported "feature" is used as the category)
# CLAP: update generic UI in response to parameter change events [p=2583184]
# CLAP: use separate persistent configuration state for renamed plug-ins
