v6.64+dev0809 - August 9 2022
* Includes feature branch: .SD2/PCM/RAW file support
+ MIDI quantize: fix some unexpected behavior when quantizing all notes vs selected notes
+ Media item fades: fade edits (without relative edge editing) affect other selected item fades as the edited position changes
+ Media item fades: when not using relative edge edit mouse modifier, edit selected item fades only if the fade start and end both line up with the edited item
+ Region manager: add option to add/remove child tracks to render list when adding/removing parent
+ Region manager: disable option to display track dropdown list nested by folder, by default
+ Region manager: when not displaying track dropdown list nested by folder, indent tracks in folders
+ Track group manager: add option to add/remove child tracks when adding/removing folder track to group
+ Track grouping manager: add option to display track dropdown list nested by folders
+ Track grouping: add razor edit left-click mouse modifier to remove one area ignoring track grouping
# CLAP: send CLAP musical events to plugin note ports that prefer it, MIDI events to note ports that prefer it
# Clap: support clap_host::request_callback [p=2584761]
# MIDI: retroactive record does not input quantize when events were recorded during stop/etc
# MIDI: retroactive record note-interesting threshold is now 1 while stopped
# MIDI: retroactive record tracks notes/CCs/pitch across loop iterations
# MIDI: retroactive record treats CCs as interesting if they occur during playback
# MIDI: retroactive record will obey overdub for events recorded while stopped
# Track group manager: when option enabled to set track selection from group selection, update track selection more quickly
# Track grouping manager: adjust radio buttons for dark themes on Windows
# Track grouping manager: improve behavior when swipe-dragging below last group in list
# Track grouping manager: improve interaction between preference to select tracks when group selected, and grouping parameters dialog
