卧室制作人博客:Get 76% OFF Enforcer Bass Plugin By BOOM Library
For a limited time, BOOM Library offers their bass-enhancing plugin, ENFORCER, at 76% off (that’s €29 with the discount applied)!
BOOM Library is often recognized for its vast collection of SFX libraries, but they also make some very intuitive plugins.
Bass frequencies are the quintessential backbone of most genres of music, and ENFORCER offers producers the ability to manipulate, fine-tune, and perfect that area of the frequency spectrum.
The Detector is a visual representation of your audio signal’s transients at the front and center of this plugin.
The Detector reads the audio signal in real-time and applies effects to your liking. Users can select from various modifiers such as the threshold, release, and filter frequency to determine precisely what frequency ranges they want to change.
Once variables in the Detector have been set, you can move on to Pitch and Amplitude.
Pitch/Amplitude allows you to choose the attack and decay of your desired frequencies along with the overall volume and power of the sound.
Unlike some drum plugins, ENFORCER uses a synthesizer to add effects or replace the specific sounds you’ve selected in the Detector window.
A final essential tool in this plugin’s arsenal is the Ducking feature. This control helps clear space from the source so ENFORCER can add color and clean up some of the low-end frequencies the plugin adds.
At the end of this chain of features is a master output in which users can set their desired mix of dry signals alongside the wet, synthesized signal created by ENFORCER.
This plugin also includes over 115 preset sounds and FX to choose from.
These presets make it easy to replace a kick in your source audio sample quickly or subtly layer in a different snare with your existing one.
A final feature is that Native Instrument Komplete and Maschine hardware users can use Komplete Kontrol to load presets.
ENFORCER is compatible with Mac OSX 10.13 and newer or Windows 8 and newer. It works with any DAW that supports VST, VST3, AU, and AAX formats.
An iLok account, along with the installation of the iLok License Manager, is required to run this plugin.
Get the deal: ENFORCER (76% OFF @ VSTBuzz)
资讯出处:Get 76% OFF Enforcer Bass Plugin By BOOM Library - Bedroom Producers Blog
