REAPER v6.66
v6.66 - August 17 2022
+ FX: fix UI glitches when showing offline FX in chain view (6.65 regression) [p=2586072]
+ Linux: improve behavior of listview clicks to listview images and manager fields
+ Linux: improve listview column alignment to match other platforms
+ Master metering: fix RMS stereo loudness readout when RMS window length has been customized
+ Media: support Sound Designer II audio files (add .sd2 extension so REAPER can identify the file)
+ Media: when loading .sd2 files on macOS, copy resource fork to plain file “mediafile.sd2.rsrc” for portability to non-macOS systems
+ Media: import files with .L/.R/.pcm/.raw extensions as raw PCM audio
+ Media: when importing raw PCM audio (including .sd2), use best-guess audio parameters and warn with instructions about how to fix incorrect playback
+ MIDI: fix stuck notes when using replace recording [t=269470] [t=255728]
+ Notation editor: fix various drawing glitches [t=269232]
+ Notation editor: improve hit testing of dynamics/custom notation [t=269376]
+ Preferences: move media/video and media/import preferences to separate pages
+ Project settings: fix enabling/disabling pan law gain compensation in project settings advanced tab (6.65 regression) [p=2586016]
+ Render: fix applying render fades when project start time is negative and also applying brickwall limiter [t=269619]
+ Render: improve behavior of option to automatically increment rendered file name [t=269586]
+ Routing/grouping matrix: improve appearance of folder expand/collapse icons
