2B Played Music offers the 2B Shaped Filter (14.99 EUR value) plugin as a FREE download for a limited time only. The offer expires in less than 24 hours.
2B Shaped Filter is a multi-mode filter effect with modulation capabilities, somewhat similar to the TAL-Filter-3 (freeware) plugin we covered recently.
It offers four different filter types (Low Pass, High Pass, Band Pass, and Band Reject), each with two different slope variants.
The filter cutoff can be modulated internally via a freely editable LFO. The LFO module comes with a selection of standard curve shapes (sine, saw, etc.), but the user can freely customize the modulation curve using the onboard spline editor. You can build the modulation shapes from scratch or edit the ones that are included with the plugin.
Filter modulation is not the only thing you can do with 2B Shaped Filter. The plugin also lets you automate the volume, a technique that works quite well for emulating the “pumping” sound of side-chain compression.
The effect is available in VST and AU plugin formats for compatible digital audio workstations on Windows and macOS. Only 64-bit plugin hosts are supported.
Here’s a bit more info about the plugin:
2B Shaped Filter is a powerful audio effect filter that reacts to the shapes you create with the advanced spline editor. 2B Shaped Filter is derived from its big brother 2B Shaped, based on customer demand.
To download 2B Shaped Filter for free, add the plugin to your shopping cart and apply the coupon code 2BFREE at checkout. I tested the code a few moments ago, and it’s still working.
On a related note, 2B Played Music offers a 60% OFF deal on two other plugins: 2B Distorted and 2B Shaped. Use the coupon code 60OFF for that deal.
2B Shaped Filter (use the coupon code 2BFREE at checkout to get the plugin for free, expires in less than 24 hours)
出处:2B Shaped Filter Is FREE For A Limited Time Only! - Bedroom Producers Blog
