v6.67 - September 7 2022
+ Actions: add action to build selected item peaks if necessary
+ Actions: respect preferences to trim media behind items, or auto-crossfade, when running action “move to media source preferred position” [t=270296]
+ AIFF: support reading ID3 metadata embedded in .aif files [t=270431]
+ Batch converter: add dropdown to choose how many CPU cores to use
+ Custom action editor: allow longer action names to display when window is resized large [t=270195]
+ Filenames: allow more than 10,000 similarly named filenames to be generated
+ FX CPU Metering: improve full accounting of CPU use (from oversampling, bypass envelope, etc)
+ Glue: ensure per-take FX are reinitialized prior to glue [t=269131]
+ JSFX: allow reading #dbg_desc from code [t=270068]
+ JSFX: fix timing of MIDI Arpeggiator [t=269926]
+ Linux: fix right-doubleclick behavior in MIDI editor keys [p=2592921]
+ Linux: fix doubleclick in track area going to correct context [t=269854]
+ Localization: add a few missing localized strings [p=2586604]
+ Localization: fix langpack definition for new media import page help text
+ Localization: improve appearance of envelope window with width scaling [t=270191]
+ Localization: improve auto-sizing/scaling for controls embedded in various file open/save dialogs [p=2589871]
+ Localization: improve control auto-resizing on Windows when used with dialog scaling [t=269228]
+ Localization: improve macOS handling of strings that have a key prefix for Windows [p=2585852]
+ Localization: support media explorer size units
+ macOS: improve mouse hit testing/cursor testing consistency on retina displays/subpixel input devices
+ Media explorer: enable metadata editing menu items for .aif [t=270084]
+ Media explorer: fix incoherent file size display for certain sizes [p=2591068]
+ MIDI: add actions to insert retroactively recorded MIDI
+ MIDI: fix incorrect ordering of certain notes in MIDI_GetRecentInputEvent
+ MIDI: improve MIDI replace recording corner cases
+ MIDI: when recording new MIDI items, show all CC data in one lane [t=270404]
+ MIDI: update arrange view when changing CC lanes in MIDI editor [t=270404]
+ Peak building: avoid full peakbuild rescan when inserting media
+ Peak building: optimize for very large projects [t=266953]
+ Performance meter: add option to show FX CPU as worst-block (for diagnosing problematic realtime plug-ins)
+ Performance meter: display track media CPU use (includes resampling, take FX, timestretch, etc)
+ Project bay: add option to disable grouping similar FX in FX tab
+ Project bay: add option to show track numbers in track column
+ Project bay: add performance column to FX tab
+ Project bay: avoid unnecessary metadata cache flushing
+ Project bay: display idle status for FX when applicable
+ Project bay: preserve selection when changing FX online/bypass, presets
+ Project bay: default new folders to expanded
+ Project metadata: support sorting metadata list by category
+ Razor edits: fix media item mouse modifier to extend razor edits to item [p=2585455]
+ ReaScript IDE: improve handling of maximize state/docking/etc [t=269228]
+ ReaSurroundPan: fix influence of height speakers in Auro 11.1 and 13.1 setups
+ Region manager: add option to add/remove child tracks to render list when adding/removing parent
+ Region manager: option to display track dropdown list nested by folder is disabled by default
+ Region manager: support sorting by “Info” column
+ Region manager: when not displaying track dropdown list nested by folder, indent tracks in folders
+ Region render matrix: support forcing individual track+region combinations to mono/stereo/multichannel render by right-clicking in region render matrix
+ Region render matrix: support selecting regions (for rendering selected regions) via click on region number or context menu
+ Region render matrix: simplify context menu
+ Region render matrix: recalculate scrollbar size/position when expanding/collapsing tracks or when region names change [t=270076]
+ Render: add button to display rendered file in Media Explorer
+ Render: don’t automatically replace .mp4 extension when setting video or audio encoder to “none” [t=269863]
+ Render: fix embedding markers when rendering selected media items and project has customized start offset [t=270010]
+ Routing/Grouping/Region render matrix: remove “view mode” options from context menu, because dropdown is always available
+ Routing/Grouping/Region render matrix: improve appearance with very long track/group/region names [t=269963]
+ Routing/Grouping matrix: improve appearance of folder expand/collapse icons
+ SD2/PCM/RAW: support reading preferred file position from resource file (after importing .sd2 file, run “move to media source preferred position” to move imported files to their position in the original project)
+ Spectral edits: fix hit testing of the bottom edge of the last channel [t=269951]
+ Spectral edits: increase the size of edge/corner hit test regions slightly
+ User prompts: use OK/Cancel for various proceed/cancel prompts rather than Yes/No [t=251472]
+ Video: fix re-enabling DirectShow media reading on Windows using dshow_depr [t=269473]
+ Video: fix video FX when applied to MIDI files that have a playrate greater than 1.0 [t=269925]
+ Virtual MIDI keyboard: highlight notes being played by armed track inputs
+ VST: fix VST2 to VST3 migration state conversion
+ VST: fix VST2 to VST3 migration mapping for plug-ins with non-alphanumeric characters in their names [t=269523]
+ VST: fix incorrect parameter changes being sent to bridged VST3 in certain instances
+ VST: avoid crashing reaper when a bridged VST3 crashes [t=270087]
+ VST: do not show default preset name of ‘Program 1’ for plug-ins that do not have multiple programs
+ VST: improve locking behavior when loading presets [t=269869]
+ Windows: fix shortcut creation for DX plug-ins [t=270111]
+ WMF: use .m4a extension when rendering audio-only MPEG-4 files
