Voxengo releases TEQ-421, a freeware triple equalizer in VST, AAX, and AU plugin formats for macOS and Windows.
Voxengo is another developer with whom I don’t have prior experience, but you can never have too many free options! The developer offers a range of free and paid plugins, with trial versions of paid products available.
The latest release is TEQ-421, an EQ plugin for macOS and Windows. At a glance, it’s evident that TEQ-421 is a straightforward plugin, and more often than not, that’s a good thing. It’s a simple three-band EQ that aims to deliver a modern tonal balance with minimal fuss.
The resizable GUI, which has multiple color variants, features just four control knobs for the Lo, Mid, High frequencies, and Out Gain.
To complement the user-friendly GUI, TEQ-421 has a handy preset manager and contextual hint messages.
The frequencies of each band are non-adjustable but were carefully selected to deliver great results in various use cases. Voxengo designed TEQ-421 by tuning to a varied range of sound sources and targeting the frequencies that most alter the perception of sound. The sound sources include vocals, acoustic guitars, bass, drums, and entire mixes.
TEQ-421 is suitable for single tracks, groups, or as a master bus EQ. Despite having various use cases, TEQ-421 is best suited for use on unprocessed acoustic recordings.
The easy-to-use plugin features built-in non-parametric harmonic coloration modules that provide additional presence and subtle saturation. These harmonic coloration modules are derived from Voxengo’s HarmoniEQ plugin.
Plugins come in many shapes and sizes; sometimes, the best option is the one with the fewest distractions. But, if you want a free EQ with a few more controls to tweak, you could check out BlendEQ from Analog Obsession.
If you want to take a slightly crazier approach, you should check out Morph EQ from Minimal Audio.
TEQ-421 is available in AU, VST, and AAX formats for macOS (10.11 upwards) and Windows (7, 8, and 10 – and later unless announced as unsupported). Both 32-bit and 64-bit plugin hosts are supported.
- BlendEQ Is A FREE Equalizer Plugin By Analog Obsession
- Variety Of Sound Releases FREE FlavourMTC Passive Equalizer Plugin
资讯出处:Voxengo Releases FREE TEQ-421 Triple Equalizer VST Plugin - Bedroom Producers Blog
