REAPER v6.69rc1
v6.69rc1 - October 18 2022
+ API: add support for GetSetProjectInfo_String(“RENDER_TARGETS_EX”), which returns the list double-null separated (“RENDER_TARGETS” is semicolon-separated)
+ Batch converter: fix support for <METADATA <TAG when using -batchconvert from command line
+ FX: Improve handling of stepped parameters when displayed in TCP/mixer [p=2593196]
+ Fades/crossfades: limit automatically created fade length to half the width of the arrange view
+ Loopback: allow configuring up to 512 channels of loopback via rearoute_loopback= key in reaper.ini
+ MIDI: fix retroactive record incorrect start time [t=270558]
+ Media explorer: fix UTF-8 issues with path combo box text [t=270328]
+ Media explorer: if media does not contain embedded tempo, display tempo implied by media or selection length
+ Media explorer: shift+mousewheel to horizontally scroll waveform preview when zoomed in (shift+drag to hand-scroll)
+ Media import: copy media to project directory if configured on paste of items/tracks [p=2600753]
+ Notation editor: by default, break beams on every 1/4 note in 4/4 time
+ Notation editor: fix caption for “Enter Text” dialog
+ Pan: fix linear-taper mode when gain compensation applied and pan law is not +0dB [t=271230]
+ Parent send: allow arbitrary channel count limits to be added to the UI in the future
+ Parent send: allow arbitrary channel counts for master/parent send
+ Razor edit: fix deleting razor edit areas with ripple-all-tracks enabled [p=2599415]
+ ReaEQ: improve analyzer update when automating/modulating global gain [t=271038]
+ ReaFIR: correct input vs output analysis gain offset
+ ReaFIR: improve analysis quality when in ‘reduce artifacts’ mode
+ ReaFIR: improve subtract mode behavior with very quiet noise profiles [t=271555]
+ ReaPlugs: improve spectrum analyzer smoothing to ensure that peaks are accurately displayed
+ ReaScript: drag/drop from FX browser to gfx windows will send filenames of @fx:fx_ident to gfx.getdropfile() [t=271052]
+ Region/Marker Manager: add option to display take markers that are outside the visible part of the media item [t=271487]
+ Region/Marker Manager: do not display per-take markers in manager unless they are within the visible part of the media item [t=271732]
+ Render: add option to write outfile.render_stats.html for each rendered file [t=263705]
+ Render: support rendering stems pre-fader from render dialog
+ Routing: allow limiting track parent send to stereo [t=270441]
+ VST: hold down control/command key during startup to suppress scanning new/updated VST plugins
+ Video: fix gfx_fillrect() alpha channel writing corner case [t=270611]
# Notation: rename “whote note trill” ornament to “trill line”
# Razor edit: fix incorrect behavior of razor edits in ripple-all mode [p=2601531]
# Render: strip rendered file path when writing outfile.render_stats.html
