Plugin Boutique offers a generous 74% OFF on the Neoverb ($25 sale price) reverb plugin by iZotope. You can get the full version for a general VST upload on your DAW or get the crossgrade option if you’re an existing iZotope user.
Neoverb is one of the most intelligent reverb plug-ins for music creators. It is developed by the geniuses behind Ozone and Nectar and driven by famous Exponential Audio technology.
iZotope’s smart reverb plugin assists you in creating distinct places for your sounds in a matter of seconds without having you spend countless hours in trial and error. A smart reverb that got your back in mixing.
The smart aspect of Neoverb is that it intuitively helps you pick and combine reverbs according to your creative requirements. Make good use of the AI-powered EQ component as it analyzes your audio and assists you in avoiding artifacts, treating mud, and masking unwanted frequencies. Explore the advanced panel with hundreds of vocal and instrument presets, then add your own creative touch to the generated reverb.
Neoverb’s developers intended to help you mix quicker and find the correct reverb blend for your mix in no time. The Blend Pad allows you to mix up to three distinct reverbs at the same time. This way, you truly have endless possibilities for how you mix your sound. Since it is AI-powered, you can also let the assistant do that for you and propose a perfect reverb for your audio.
Make use of the blend pad automaton in your DAW to create a dynamic reverb that follows the movements of your sound and applies reverb accordingly. Try it a couple of times and mess with it in different productions to see how it works and adapts to varying inputs.
If you’re keener on getting your hands dirty, then Neoverb offers a dozen presets that you can personalize at will and create your own touch.
It comes with an advanced panel where you can customize your reverb, a reverb eq to clean it from artifacts, a pre-eq to make sure your input is clean before reaching the reverb processing, a masking meter to get rid of any muddiness that might still prevail, and a smooth pre-delay and mixing controls to add more customization to your delay.
Neoverb comes in AU, AAX, VST2, and VST3 64 bits plugin formats, and is compatible with operating systems ranging from macOS 10.13.6 El Capitan to macOS 11 Big Sur (Intel-only, M1 Apple Silicon NOT yet supported) and Windows 8 to Windows 10.
It is supported by a variety of DAWS such as and limited to Logic Pro X, Live 9.7–10, Cubase 9.5–10.5, Pro Tools 12–2020, FL Studio 20, Studio One 4, REAPER 6, Reason 11, Bitwig Studio 3, Cakewalk by Bandlab, Digital Performer 10.
Get the deal: iZotope Neoverb (74% OFF @ Plugin Boutique, $25 sale price)
- Mixing Music: The Simple Guide For Music Producers
- Waves Audio Will Release A FREE Plugin On Black Friday 2022
资讯出处:Get 74% OFF iZotope Neoverb @ Plugin Boutique - Bedroom Producers Blog
