Karanyu Sounds offers the Vapor Dimensions ($49 value) modulation plugin as a FREE download for a limited time.
Vapor Dimension is a vintage-style modulation plugin by Karanyi Sounds. Packed full of chorus and phaser effects, this plugin is great for widening sounds and achieving 70s-inspired psychedelic textures and “colors from another dimension.” You can download it for free for a limited time.
“Introducing Vapor Dimension. a studio-quality modulation plugin that adds rich, vintage colors and wideness to your synths, keys, pads, guitars, vocals, and more! 20 built-in DSP algorithms, easy on CPU, and user-friendly interface.”
The developers at Karanyi Sounds have designed this plugin with simplicity in mind. With just two controls, users can spend less time fiddling with knobs and more time playing, experimenting, and producing.
There are 17 modulation presets to play with here, designed for a range of instruments. These include a variety of modulated effects for guitars, lead and bass synths, pads, and bass guitars.
The “Type” control affects sub-categories of modulation (from gentle to heavy), whilst the “Modulation” control allows you to fine-tune the effect. Whilst only having two controls, I think that this is enough to satisfy most producers – there is still a lot to play with here.
Vapor Dimension also features a “Random” button to randomize the plugin’s parameters. This is a great feature that can provide instant inspiration – producers who don’t want to waste time menu-diving can press this button until they come across the perfect sound.
Overall, the presets sound great – they are well-engineered and effective. Some of the presets were designed by artists – and so the mix of factory and artist-made sounds is an interesting feature.
Some of the modulation effects here are quite subtle, but this is useful for producers wanting to add a little flair to their mix without drastically changing a sound. This plugin is particularly good for widening sounds and breathing new life into thin or lifeless guitar and synth takes.
On a related note, Karanyi Sounds currently offers up to 80% OFF in discounts on various best-selling products.
Vapor Dimensions is available in VST/VST3 for Windows and VST/VST3 & AU for macOS. You can download the plugin for free from Karanyi Sounds for a limited time.
- UnitedPlugins Release FREE TrapTune Second-Hand Edition Plugin
- Experiverb Is A FREE Experimental Reverb Plugin By Audiomodern
资讯出处:Vapor Dimension By Karanyi Sounds Is FREE For A Limited Time - Bedroom Producers Blog
