Plugin Boutique offers the Fat Channel XT ($59.95 value) channel strip VST3/AU/AAX plugin by PreSonus as a FREE add-on with any purchase this month.
Fat Channel XT is a multi-effect channel strip developed by PreSonus. The software is compatible with all 64-bit VST3, AU, and AAX plugin hosts on Windows and macOS.
The plugin delivers a selection of vintage-style audio effects to any digital audio workstation. It’s an all-in-one solution for channel compression and equalization, as well as limiting, filtering, and gating. It combines the most-used mixing tools in a single, easy-to-use interface.
Fat Channel XT comes with three different EQ models and three compressors.
The available compressor models are:
- Standard – modern compressor with a clean sound;
- Tube – modeled after a vintage tube-based optical compressor;
- FET – based on a vintage FET compressor.
And here are the included EQ models:
- Standard – a modern equalizer with a clean sound;
- Passive – emulation of a vintage tube-based passive-EQ;
- Vintage – emulates a classic solid-state equalizer.
In addition to the included compressor and EQ modules, Fat Channel XT also features a built-in limiter, a filter, and a noise gate module.
Here’s how PreSonus describes the Fat Channel XT plugin:
“From the moment the original StudioLive shipped over a decade ago, the Fat Channel was an instant hit. With a fully variable high pass filter, a noise gate designed to never click, a musical compressor based on PreSonus’ famed ACP88, a four-band parametric EQ, and a Limiter to round it all out, the Fat Channel gave StudioLive users all the tools they needed to craft the perfect mix.”
To claim your free copy of Fat Channel XT, complete a purchase at Plugin Boutique and be sure to activate the “free gift” option at checkout. The free download offer ends on June 30th, 2021.
Fat Channel XT (FREE with any purchase @ Plugin Boutique)
资讯出处:PreSonus Fat Channel XT Is FREE With Any Purchase! - Bedroom Producers Blog
