卧室制作人博客:Get 92% OFF iZotope Holiday Bundle @ Plugin Boutique
Plugin Boutique is offering 92% OFF the iZotope Holiday Bundle. This unique offer is ideal for studios of any size since it includes mixing and mastering plug-ins worth over $600 in total for just $49.
Get yourself different iZotope Elements for different purposes. With the new Ozone and Neutron Elements, you can quickly produce immaculate mixes and masters with increased performance. Then, via the new Audiolens app, tune in your tone with easy track-referencing from any source or streaming platform.
Finish with time-tested metering from Insight 2 for perfect track loudness and unparalleled reverb clarity with Stratus by Exponential Audio.
Let’s take a closer look at the tools included in the iZotope Holiday Bundle.
Ozone Elements
With the new Master Assistant, you can get the sound of chart-topping songs or your favorite reference file by employing breakthrough matching technology for tone, dynamics, and breadth.
With the redesigned Assistant View, you can easily tailor the processing recommendations to your preference and work quicker, thanks to native Apple hardware support. It’s the simplest and most cost-effective approach to getting your music ready for broadcast.
Neutron Elements
With Neutron Elements, the contemporary, AI-powered channel strip, you can sculpt sounds while keeping in your flow and mixing in the moment. The revised Assistant sits in the new Assistant View and automatically proposes audio processing that may be fine-tuned to your preference, allowing you to mix quicker.
Real-time reference matching It’s almost like magic. Using the new Target Library with tone-matching technology, you may dynamically match the tone of your track to a sample or stem. Load stem references into your Target Library to enable the Assistant to match your drums, bass, guitar, voice, or audio recording to the sound you want to achieve.
iZotope Audiolens
The new Audiolens desktop program makes your life easier by analyzing music from any streaming platform or audio source. It simplifies track referencing and comparing.
Play your preferred music through your device’s selected output, and the app will gather data on important sonic properties, allowing you to view, compare, and match your favorite reference songs and sounds. The best part is that you can stream references right from the source platform.
Insight 2
Insight 2 is a sophisticated audio analysis and metering plug-in that is used in award-winning post-production studios, music studios, and broadcast facilities. It’s ideal for visualizing mixing and mastering changes, troubleshooting troublesome mixes, monitoring dialogue intelligibility, and assuring compliance with broadcast loudness regulations.
By monitoring your audio with the best precision, you may save time and money while mixing and mastering. With Insight 2, you can keep an eye and an ear on your mix at all times.
Stratus
Stratus’s clean and realistic reverb algorithm adds a sharp, authentic depth to any post-production session. To create the ideal ambiance for your next project, use Stratus’ detailed, channel-specific timbre and timing parameters to fine-tune your tone with ease and accuracy.
Stratus allows you to create genuine surround soundscapes for your mixes with unrivaled reverb clarity. Get precisely the perfect amount of depth and dimension in any post-production work with up to 7.1 surround support, over 1,700 presets, and familiar, intuitive controls over every channel.
This plugin bundle comes in VST3, AAX, and AU, and is only available in 64-bits.
Get the deal: iZotope Holiday Bundle
资讯出处:Get 92% OFF iZotope Holiday Bundle @ Plugin Boutique - Bedroom Producers Blog
