v6.73+dev0104 - January 4 2023
+ CLAP: fix default path list on Windows [t=274405]
+ Grouping: reset automatic track grouping to default when creating new project
+ IDEs: fix inconsistency in column indicators, improve behavior of Ctrl+End (thanks to Giorgos Vougioukas)
+ Media explorer: add action to calculate peak volume for all media (will skip files that have already been calculated)
+ Media item lanes: add action, mouse modifier to create razor edit preview on first playing lane
+ Media item lanes: add actions, mouse modifiers to change razor edit preview lane
+ Media item lanes: razor edits on lanes that are playing can optionally preview media on other lanes
+ Media item lanes: when razor edits exist on a playing lane, indicate which other lane contains the same media
+ Razor edit: action to enclose media items in razor edit creates a separate razor edit area for each selected media item, rather than a single razor edit enclosing all selected media items
+ Razor edit: fix envelope cut/paste (6.72 regression)
+ Razor edits: fix action to move razor edit areas up/down/forward/back without contents for master track [p=2630344]
+ Razor edits: fix undo for razor edits on master track envelopes [p=2630348]
+ Razor edits: handle master track in action to move nearest razor edit edge to cursor [p=2630311]
# JSFX: fix step count for parameters with negative range [p=2619006]
# Media item lanes: avoid playing stale buffer when adding new recorded item to new lane [p=2630298]
# Media item lanes: do not move razor edits to playing lane after action to copy media
# Media item lanes: don’t show razor edit up/down/commit controls if the razor edit spans all lanes [Cockos Incorporated Forums - View Single Post - v6.73+dev0102 - January 2 2023]
# Media item lanes: fix action to toggle playing lane under mouse when tracks are grouped [p=2630326]
# Media item lanes: fix display of razor edit up/down/commit buttons on retina
# Media item lanes: handle grouped tracks when moving razor edit areas by lane
# Media item lanes: only display fixed lane up/down/commit buttons on razor edits when all razor edits are on fixed lanes
# Media item lanes: preserve “all lanes play” when inserting new lane [p=2630451]
# Media item lanes: remove unused lanes at bottom of track after action to delete lane [p=2630449]
# Media item lanes: when deleting lanes so that only one lane remains, ensure the remaining lane is set to play back [p=2630132]
# ReaScript: fix gfx window titles
