v6.73+dev0110 - January 10 2023
+ JSFX: if tags: instrument is present in header, treat as an instrument
+ Razor edits: only copy fade-in/fade-out if the start/end of the media item is included in the razor edit
# MIDI editor: fix screenset restoring empty editor when configured [p=2633160]
# Media item lanes: action to duplicate lane also copies any existing comp areas
# Media item lanes: always pool MIDI media when comping
# Media item lanes: dragging within an existing comp area only creates an embedded area when dragging on the comping lane
# Media item lanes: fix action to comp into a new empty lane
# Media item lanes: fix behavior when editing right edge of comp area [p=2633131]
# Media item lanes: fix incorrect track grouping when creating comp area
# Media item lanes: improve behavior when comping MIDI media
# Media item lanes: only mirror fades if the start/end of the source media is within the comp area [p=2633090]
