v6.73+dev0111 - January 11 2023
+ Audio Units: fixed parameter unit name on bridged plug-ins
+ Audio Units: support custom string displays for parameters [p=2456294]
+ CLAP: support text_to_value to improve manual editing of envelope point parameters
+ JSFX: improve manual editing of envelope points for parameters that are named enums
+ LV2: improve manual editing of envelope points for parameters that are named enums
+ Media item lanes: add option (in Options/New recording that overlaps existing media menu) to play only the recorded-into lane after new fixed lane recording
+ Mouse modifiers: add action/mouse modifier to join comp area with following comp area on the same lane, assuming no other comp areas between
+ ReaScript: SetMouseModifier(ctx,-1,-1) will reset all modifiers to default for that context, SetMouseModifier(-1,-1,-1) will reset all modifiers to default for all contexts
# Audio Units: release parameter name/unit strings according to spec
# Media item lanes: editing lane name affects grouped tracks as well
# Media item lanes: improve behavior when editing comp areas that exist on the comping lane only
# Media item lanes: improve behavior when multiple lanes contain copies of the same source media [p=2633742]
# Media item lanes: update lane buttons after recording into an existing lane
