v6.73+dev0112 - January 12 2023
+ Actions: fix action to duplicate items not respecting group disable setting [t=272939]
+ MIDI: do not automatically re-color MIDI media items when doing pooled copy
+ MIDI: improve behavior with replace recording mode
+ Media item lanes: when a comping lane is set, mouse modifier context “fixed lane when comping is enabled” applies
+ Media item lanes: when comping lane is set, by default unmodified drag and click creates, edits, and moves comp areas
+ Media items: fix potentially-dropped MIDI events at end of item [p=2625908]
# Media item lanes: allow reordering lanes by dragging anywhere around the lane button
# Media item lanes: another fix for remnants possibly being left behind when moving comp areas quickly
# Media item lanes: avoid showing lane-add area after moving empty razor edit to master track [p=2634166]
# Media item lanes: fix artifacts left behind when moving comp areas very quickly in both horizontal and vertical directions
# Media item lanes: fix creating comp areas on grouped tracks [p=2633965]
# Media item lanes: fix reordering lanes on grouped tracks
# Media item lanes: lane name display changes
# Media item lanes: remove right-drag mouse modifiers to create comp areas
