REAPER v6.73+dev0114
v6.73+dev0114 - January 14 2023
+ Actions: add play/stop (move edit cursor on stop)
+ Media explorer: support editing metadata via right-click menu for .mid files [t=274771]
+ Media item lanes: add mouse modifier/action to force sync media within comp area
+ Virtual MIDI keyboard: fix entering center note via keyboard
+ Virtual MIDI keyboard: improve keyboard navigation
+ Virtual MIDI keyboard: remove space from note names
# Keyboard sections: alternate main sections get default binding of ESC=clear section override
# MIDI split: fix incorrect note added after split
# Media item lanes: allow editing media in comping lane (affected comp areas will immediately go out of sync)
# Media item lanes: allow editing media item edges and fades that line up with “open” comp area edges
# Media item lanes: improve comp area syncing logic
# Media item lanes: number lanes by default, but reorder numbers when adding/removing/reordering lanes
# Media item lanes: remove option to record into (classic) takes while loop recording in fixed lane mode
# Media item lanes: respect TCP control locking
