v6.73+dev0116 - January 16 2023
* Includes feature branch: seek options on item click/select mouse modifiers
+ Media item lanes: add highlighter_select, highlighter_move, highlighter_left, highlighter_right, highlighter_lr cursors
+ Media item lanes: add option (Options menu, New recording that overlaps existing media) to promote new recording if currently comping
+ Media item linked lanes: mouse modifier/action to consolidate comp areas on the same lane consolidates all adjacent areas
+ Mouse modifiers: add option to seek when selecting items via click
+ Mouse modifiers: fix support for binding actions with small ID numbers to click/doubleclick contexts
# Media item lanes: adjust comp areas when inserting or deleting time in project
# Media item lanes: allow editing fades on items within comp area in comping lane
# Media item lanes: auto-remove empty bottom lanes after reordering lanes [p=2635427]
# Media item lanes: avoid overdrawing comp areas when recording [p=2635365]
# Media item lanes: fix comp editing corner case [p=2635424]
# Media item lanes: fix crash when clicking on lane name area of a fixed lane track that only has one lane
# Media item lanes: fix cursor consistency when resizing TCP height or TCP lane name width [p=2635432]
# Media item lanes: fix reordering lanes when multiple comping lanes exist [p=2635422]
# Media item lanes: fix splitting unsynced comp area [p=2635421]
# Media item lanes: improve display of comping lane indicator when displaying only one lane button
# Media item lanes: improve lane name encoding in .rpp (lane names saved in earlier versions will not be loaded)
# Media item lanes: improve various click, right-click, double-click behaviors on lane buttons
# Media item lanes: prevent initiating comp area edit outside of lane area [p=2635425]
# Media item lanes: support assigning arbitrary actions to lane button click [p=2635429]
# Media item lanes: use correct theme blend mode for comp area display [p=2635431]
# Media item lanes: when comping lane is soloed, new recording does not un-solo
# ReaScript: fix SetMouseMapsForContext partial reset
