v6.73+dev0118 - January 18 2023
+ Linux: do not fully unload lv2 plug-ins when destroying, fixes compatibility issues with some GDK-using plug-ins
+ Media items: support healing items even if one or both contains empty takes
+ Media items: support healing splits even if items do not have the same active take lane
+ Recording: fix aligning takes when recording pass starts in the middle of a looped section [p=2636585]
+ Recording: when loop recording, do not split recorded media even if a full loop pass was not recorded
# MIDI: fix empty events left at end of item after split [p=2636612]
# Media item lanes: comp area display tweaks
# Media item lanes: comp area edges are sticky only if areas were adjoining at the start of the edit
# Media item lanes: comp area edits are nondestructive to other areas during the edit
# Media item lanes: fix comp areas incorrectly displayed as synced
# Media item lanes: fix syncing behavior when multiple lanes contain copies of the same recording
# Media item lanes: preserve comp area sync after splitting the start of an item [p=2636465]
# Media item lanes: re-sync comp areas during edits if possible
# Media item lanes: rename mouse modifier from “Move comp area allowing empty space between comp areas” to “Move comp area without affecting other comp areas”
# VKB: improve accessibility string for keys control
