v6.73+dev0124 - January 24 2023
+ Accessibility: improve descriptions of ReaEQ/ReaPitch/ReaDelay enabled buttons
+ Accessibility: set description for FX active (bypass) checkbox
+ Actions window: when sorting by command ID, sort by identifier string [t=275016]
+ Menu/toolbar editor: increase width of listview columns [p=2636334]
+ Notation editor: fix UI quirks when the piano roll is set to project synchronized time base [t=260878]
+ ReaEQ: correct label for band bandwidth parameter
+ Track manager: fix visibility of collapsed child tracks when filtering [t=275048]
+ VST3: Add compatibility option to report master track context as track 0, for plug-ins that do not fully support this extension [t=264048]
# API: fix SetMouseModifier with command IDs [p=2638696]
# Keyboard sections: alternate main sections get mostly-default bindings, fix issues with reset all modifiers/etc
# ReaReaRea: add tempo-synchronized fade modes
