v6.73+dev0124a - January 24 2023
+ API: improve performance of SetMouseModifier()
+ ARA: Old projects may not load correctly! If the project contains separate ARA edits to multiple media items that use the same media source
+ ARA: associate edits more persistently with the source audio file
+ IDEs: suggest list does not respond to mouse movement when inactive [t=275197]
+ Notation editor: improve layout when resizing in continuous scroll view [p=2032295]
+ Tooltips: prevent tooltips from occuring when window is inactive [t=233380]
# API: optimize performance of SetMouseModifier() reset of single section to defaults
# Actions window: add menu item to copy main section keyboard shortcuts to alternate section
# Media item lanes: improve behavior when a short comp area moves through a longer comp area
# Media item lanes: internal changes
# Media item lanes: support automatic crossfade between comp areas (not yet editable or configurable)
# ReaReaRea: add dotted and triplet modes
# ReaReaRea: change tempo sync range from 1/128 to whole notes
