v6.73+dev0124b - January 24 2023
* Includes feature branch: ARA stability improvements (note: projects created in this development build may not load in earlier release versions with all ARA modifications intact)
+ ARA: modifications per media source will be more stable, use less RAM and disk, and work better when comping in lanes
+ ARA: projects created in this version and later will persistently save with modifications per media source (new style)
+ ARA: projects saved in REAPER 6.73 and earlier will load and persistently save with modifications per take (old style)
+ ARA: projects saved in REAPER 6.73 and earlier will load with all modifications retained in later versions of REAPER, but modifications will always be per-take (old style) in those projects
+ ARA: projects saved in this version and later (new style) may not load with all modifications retained in older versions of REAPER
# Accessibility: Fix VST preset/bypass button descriptions, give them all a common langpack section
# Splash: fix elastique startup message on systems with non-latin code pages [t=275177]
